Hi everyone,
Long time lurker first time poster.
I'm having a bit of an issue caused by my air compressor. To save precious floor space in the garage I keep my conpressor in the basement and plumbed air to to garage with a RapidAir kit. The problem I have is when I blow down the tank all that moisture is causing a mildew odor in the vicinity of the compressor. I do use a water separate on the main pressure line and one at each drop with an online oiler and haven't had any water related issues with my tools.
The unit it a 30 gallon, twin cylinder oiled machine running on 110v. The tank collects quite a bit of water, I think maybe because it's in a basement and basements are sort of known for being a humid environment.
I use a ball valve on the drain. I'm struggling to come up with a way to collect the water versus allowing it to blow out into the atmosphere. If I plumbed in a water separator it would end up being higher than the lowest part of the tank. Would this still work given there is 100+ psi driving the water out? Or would water still collect at the lowest point?
