copper pipe cutting
klhitman
pewee valley
i work in hvac and have the need to cut 1 3/8 pipe in close quarters, i have a chain cutter but doesn't cut very well. i have about a 3 inch spot to cut the pipe any suggestions? and it acr soft copper if that helps. i find that a grinder and a debugger works OK but i need something better!!!
gorilla
This sounds like a good application for a small air powered panel saw. Harbor Freight sells them cheap.
K
klhitman
pewee valley
as it's only 1.3/8 copper just use a hacksaw blade
sorry don't even have room for a hack saw. next time i have to do that i will try to tack a pic and show you all. i have used a sawzall in the past but you cant get a fitting back on to the pipe. i wonder if and oscillating cutter would do the same? and did i mention it is soft copper?
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Sometimes a person has to cut the pipes back to where they CAN get at them.
A hacksaw blade can be used without the frame. There are blade holders for that use or you can just wrap some tape or slip some tubing over part of the blade for a handle. Do not use the ALL HARD hacksaw blades for this purpose. They are brittle and shatter.
Hlidskjalf
Toronto
Grinders, hack saws, and sawzalls are out of the question for cutting refrigeration tubing (assuming you are not just demolishing).
I have never come across a close quarters 1 3/8" cutter. Taking a picture of where you're working would help for suggestions.
K
klhitman
pewee valley
thanks. and i will try to take a pic the next time that job comes up in my shop but they are few and far in between.
nate379
Palmer, AK
Why do you say that? Like I said that is what I use.
