Copper Tubing Question
Skiff Builder
Southern NJ Coast
I have quite a bit of lineset left over from a mini split install. Looking to run a water line for a refrigerator/ freezer ice maker.
Will the 1/4” line work with standard plumbing fittings?
Thks
Skiffbuilder
brewchief
If it's 1/4" od tube it will work fine, we buy dozens of rolls of 1/4" refrigeration copper for doing humidifiers every year.
If you are running the water through a reverse osmosis filter first then don't use copper, there is something about that process that will make the water eat the metal line up over time.
Skiff Builder
Southern NJ Coast
It worked. Got a valve/T attached to existing sink supply stop. That had a push to fit for the 1/4 tube. Compression nut on fridge end finished it up.
BTW the valve I got was a John Guest made in England. Never heard of it. In honor of the royal wedding
Thanks
Skiff
