Hi guys, finally got around to putting the block grinder back together after painting and sourcing replacement parts and then forgetting about the project for a few months. Went to put the stator (or is it field?) coil back in-between the halves and realized the wires were worse than I remember. Besides appearing to be aluminum (or ancient copper), the insulation is toast. The stranded wire is exposed where the wires come out of the magnet. I put shrink tubing on one that was split higher up, but the other one looks like the insulation is gone at the base. I can probably shrink tube it till the magnet but I worry about the exposed wire below that level.
I don't know if that can short across to the copper windings, but it seems like a bad thing. Any suggestions? Liquid electrical tape maybe? Can a motor shop replace those wires? Just find a new stator?
It's your standard 1/3 hp block grinder if that makes a difference.
crappy cell pics, brown wire is the worst (3rd pic shows this best):
