Craftsman Drill Press Conversion question
dngrmse
Northern NJ
Hey Guys, just wanted to know if anyone has converted a 50's era King Seeley Craftsman drill press from floor model to a benchtop? Or is it too much trouble to bother?
zkling
Serious question? Are you capable of safely using a drill press?
Best case you slide the head down and let the extra column stick out above. Worst case you cut the column down. Granted the base on a floor model is a bit larger in surface area than a true bench model, but...
Or you can build a cabinet under the table and leave it a floor model.
D
dngrmse
Northern NJ
Yes, serious question. I know of a bechtop model that's in rough shape, and a floor model in really good shape. Wondering if the diameter of the column is the same.
jakemac
New England
Only if the two were the same era and model. I believe that King Seeley used two different diameters, depending on the model. Bring a caliper with you when you take a look at them. The inner wall thickness shouldn't matter, it's the outside diameter that will need to be the same.
rsanter
visalia ca
I'm confused....
If you know of a floor model in good shape then why not just get and use the floor model?
If you are lacking space then cut a U in the bench or drill a hole in the bench and position the drill press in the bench.
Or how about shorten the bench. Typically cutting down a drill press reduces its value and in cases its usefulness
Bob
D
dngrmse
Northern NJ
Well, I just got back and I bought it. For $50, how could I not? But to answer the questions, the reason I had my heart set on a benchtop was because I already have this base for it:
Here is the press this is the photo from the Craigslist ad-
I will have to now either find a different power tool for that base or just sell it.(the base that is)
nine4gmc
Dallas
Damn good score, if you were local, I'd swap you a bench base and pole for that floor model base/pole. I agree with Jake, find a grinder or buffer for that base cabinet.
zeet
Southern California
$50??!! Great Score!!
Okay, I'll say it.... You ****! ;^)
The post diameter should be 2-3/4" on that model and yes, King-Seely did make a bench model with that diameter post. Fact is, I just picked up a post and a base for the same reason.... I wanted to have a "convertible" with both options.
D
dngrmse
Northern NJ
Thanks for the "you ****" And the belt sander is a great idea; you guys are a bad influence! I'll keep my eyes open for one of those now, but first i really need to offload some odds and ends I've been accumulating. I counted up my bench grinders the other day, and I'm up to 11. I need to get that down to 3, or 4 max.
D
dngrmse
Northern NJ
Good observation. I have a pretty good table saw so I have no need for it, so it's one of the items Ill be selling soon.
bluebolt
Benton LA
Will the RAS base fit OVER the drill press base? If so and you still have enough rom for most drilling projects I would do that. It's one reason I am looking for another RAS base. Put casters on it and roll it out of the way if needed for a large drilling project.
