Craftsman Table Saw: 103 vs 113
cash68
Keeper Of Rotor Hill
Milwaukee, WI
So I’ve been looking at vintage Craftsman table saws, and I see people generally have a 103 or a 113. Initially I thought the 113 was the 10” blade, but it now seems that both are 8” blades? Which saw is the one to shoot for? I see multiple 103s in my area for $100-150.
Also, how much is a pedestal worth? One has a cast pedestal, the other has a stamped frame.
nine4gmc
Dallas
They both came in 8" and 10" versions iirc. The pedestal is harder to find and more value than a stamped steel base but holy **** does it **** to move around. The stamped base is easier to modify a roller base to if you want something you can roll outside and use. If you plan to use it and store it in the same place, the pedestal is a better choice. jmo.
What Toothaker said, the first three are the manufacturer code, it's the digits after the dot that show the model.
thehorse13
Jefferson County, WV
I have the stamped steel base with my 1958 Craftsman 8 inch saw. Everything in this thread is 100% accurate. The stationary base is fantastic but insanely heavy. The stamped base is sorta cheap but it's light weight and lends to easy moving.
Because I need to move my saw, I went with two stationary casters mounted to the side of the stamped steel base so that I can roll it like a wheel barrow when needed.
ckadams00
Seattle, WA
Pedestal base for the win!:beer:
Saw comes second.:thumbup:
Figure out how you are going to use it. But take the pedestal base regardless. They're worth as much as the saw and much harder to find.
