Galaxywide
I'm not sure this is the right place, since technically this isn't flooring, but it is garage and concrete so figured it would be relevant.
My garage is built slightly below grade, and the bottom 30" or so of the walls are stacked blocks, with standard stud walls above. I appear to have a moisture problem or problems, since during freeze/thaw cycles I get substantial water coming through or under the walls and into the garage (ice buildup this winter reached 2" in the corner! I'll have heat this winter, but still). I suspect this is causing at least some of the damage to the blocks, but I'm not sure how to prevent it without doing a lot of digging and breaking up a large patio slab that (unfortunately) slopes down to this wall at one corner (the corner that the most water generally comes in). The blocks near the main door (you can just see the photoeye in picture #3) are particularly bad, and I'm worried about their strength supporting the wall above if the crumbling continues.
The garage does have gutters, routed well away from the building.
I'm looking for a way to repair these blocks, and thereafter seal or protect them in some way as well as to seal the walls against further leakage into the garage. I went to the local big-box store, and while there are a variety of concrete patch, repair and seal products I'm not sure which to use....they all seem to have overlapping uses at many different price points.
I don't know much about concrete, so any suggestions are welcome!
