Deadblow Uses
Shootinok
Oklahoma USA
Since I jumped on the Trusty-Cook pink hammer deal, I've found myself using a deadblow hammer for things I hadn't used one for before. In fact things I hadn't thought of needing one for.
A couple examples are Framing - Yep wood framing.
I was tapping (beating) in 2x wood for window headers and a hammer was making deep marks in the wood. I grabbed the #3 pinky and they moved in much much easier with zero marks in the wood.
Another was tapping wood over a bolt in a column. A hole drilled in a wood 2x6
needed to be tapped onto an bolt projecting from a column. No muss No fuss and no little round dents.
What are some things you guys use dead blow hammers for?
Derek420
Southern Indiana
Im wanting to buy the pink trusty cook dead blows do they feel nice in the hand and how's quality I need them to help loosten rusted bolts like to hit my wrenches and ratchets with and not mark them up.
jakemac
New England
When I was working building temporary exhibits, we used heavy 4'x10'x4-1/2" pre-made panels for the walls. One of my co-workers had a big red 3lb deadblow in his toolbox. Whenever we had a stubborn panel that wouldn't seat properly, someone would yell across the room for "The Clown Hammer" to beat the panel into place.
Shipfittin
Portsmouth, VA
I reach for my deadblow all the time. Just about every time I want that big hammer but I don't want to scar up whatever it is I am hammering, it's the deadblow. If I am going for my maul, something is in for a lot of pain.
Shootinok
Oklahoma USA
Really nice !
I bought two (#1 and #3) and was so impressed with the quality I bought 5 more. Three are the blue thin lines and 2 more pinks (2 for gifts).
I want my son to have that quality too. He's a trim carpenter and really likes the #1 for joining and plane work.
winlinmac
USA
I'm sure using a deadblow in conjunction with a dolly would be useful body work touch ups right?
jsaw
Geneva, N.Y.
i use it to pop off rested brake rotors & drums, also to hammer on wrenches. I had a caliper bracket bolt a couple weeks ago that I could not get loose. I tried a pipe over the wrench , still would not come loose. a couple pops on the wrench with the dead blow broke it loose
ChaseDE
Delaware
dead blow got extensive use yesterday replacing an axles on the wifes suv. first time really using it, twas great.
Cruzan80
Denver, CO
Manual flooring nailer. Gave me much more "oomph" for seating cleats thru hardwood.
General "Persuasion" uses.
dutchgray
Dorset. England.
Recent uses for mine has been laying paving slabs, beating pvc ducting together and beating a flat bar under plaster coving to get it off.
davethorik
Norka, Ohio
Among other things, i help build swimming pools and some of the above ground models have AL skinned polystyrene foam panels for walls with aluminum spline extrusions on the ends. Separate smaller spline extrusions are slid in to lock the panels together. My Proto 3 lb dead blow is great for helping them in place.
