Desmond Stephan 51S screw
Sawmill7
Iron River Mi
I am still looking for screw or measurements of diameter and tpi and pitch. If someone could measure a screw they have I do have someone who will make it for me thanks for any help. Bill
SkyPuncher
Hi Sawmill7, my old Desmond Stephans 51P was easy enough to get to and I would think the measurements would be the same between the swivel and non-swivel version. Some of this might not be useful to you, but here is what I got. Let me know if I could do something better or you need something else.
Total length of screw with "hockey puck" 19 - 5/8"
Screw up to the "hockey puck" 16 - 3/4"
Length of threaded portion 12 - 1/4"
Diameter 15/16"
TPI 4 threads per inch
Handle length 14 - 1/2"
  • Like
Reactions: RTM
Sawmill7
Iron River Mi
Thank you very much so is there a certain name for the threads..witworth..acme..or something else? Just in case the machinist asks. Only thing I can give him is the nut off the vise. I really appreciate you getting these measurements for me..will post a before and after pic when completed
Thank you. Bill
SkyPuncher
Well Sawmill, I would say it is Acme thread. Now I have been known to be wrong from time to time and if you are looking for a second opinion, I would try here:
But per this article:
ACME threads are commonly used in clamps, vises, and linear actuators. The main advantage to an ACME thread is a low number of threads per inch. This allows ACME threads to allow for increased linear actuation per turn of screw which is similar to a square thread. The difference between square threads and ACME threads is the angled root of the ACME thread. The angled root allows for ACME threads to be more easily manufactured compared to the square root of a square thread. The root of an ACME thread is also larger which delivers increased strength in preventing stripping and wear of the thread. It should be noted that the typical controlling failure mechanism of a screw is torsional shear which is based on the minor diameter of a screw and not on the type of thread.
Let me know if you need any other measurements and I'll be happy to help!
RoninB4
Under My House
Not wanting to cause trouble here but a quick search on the internet showed no standard Acme thread at 15/16" diameter, they go from 7/8 to 1" in diameter. Furthermore, the TPI for a standard Acme thread of that size is usually 6 TPI. A check in my well worn copy of Machinery's Handbook (20th edition) that shows many variations of thread types doesn't list an Acme thread like that either. The OD isn't all that critical to identify an Acme but the thread form, pitch diameter, and root diameter is important. What is also important is whether the TPI is single start or multiple starts, uncommon but not unheard of. If the OD is 15/16 it might be a metric 24 MM but only if it was not made in the USA and it's an older vise but the Desmond Simplex appears to have been made in R.I.
There are at least 3 types of Acme threads and an untold number of "Modified Acme" in existence. All have slightly different geometry/dimensions. I'm not stating that the OP has a non-standard thread but my references/searches indicate this is likely. Sometimes tooling for items like this were/are non-standard to ensure replacement from the factory and nobody else. Also, some industries (like makers of vises, microscopes, plastic containers, etc. ) use designs that are sorta standard to them and no/few other industries.
To the OP-If you're going to have a new lead screw made by a shop I'd suggest you take them both the lead screw AND the nut. Anything non-standard can be made but a new lead screw and nut may be a simpler (but a bit more expensive) a solution to ensure proper fitment. Post what happens and/or price quoted for this if you don't mind.
Sawmill7
Iron River Mi
Thanks for your input. As the picture shows the screw is broken off right at the start of the threads and the threaded part is missing. I can only show machinist the nut.
SkyPuncher
Looking back at the picture, you guys are right, it does look square and theres the catalog that mentions it. Good eye! I can take a closer look tonight now that I now what to look for. I am far from any kinda expert on the subject and not even that good at taking pictures! Great thing about this forum is the amount of knowledge floating around!
G-ManBart
Most vintage bench vises I've handled (hundreds) have square threads, not Acme. In many cases they are non-standard. As an example, I just fixed a Parker 975 screw and it was 1.10" and 3TPI square thread...you won't find that in any book. The machinist is going to need the nut to confirm fit since it's likely non-standard and should be able to confirm the thread type. In a worst-case scenario a casting of the nut could be made using Cerrosafe that would unthread and could be measured. Cerrosafe is normally used to make precise castings of gun chambers that are dimensionally accurate after cooling.
RoninB4
Under My House
-Yes it's broken off at the start of the thread but there may be enough of the thread form to determine whether it's a square thread or not. Other members here have posted that a square thread is somewhat common for older vises (don't recall mine) so even a broken nub may be enough to gather some information. The experiences of the other members here is more valuable than my experience as just toolmaker.
Maui
Upstate NY
Please let us know what this costs you. Some of us have vises with similar issues.
Tober
Home
Have you ever resolved this?
I also have a 51S vise in very good condition except for the nut, it was swapped out for one from a different vise and it does not fit properly
i would love to get dimensions and pictures of an original one. Or perhaps someone out there has a 51S for sale? I seldom see them
Sawmill7
Iron River Mi
Had a new screw and nut made. Friend is a millwright and ordered a new 3' piece of rod an2 nuts and made it all work.
