Different Fish Tapes for different uses
mobiledynamics
Gotham City
Not a pro sparky, but curious for those in the field, what whats for what application. I have the usual carbon and SS steel for the usual fare, and the Ideal Zoom - nylon jacketed braided SS, which I prefer to use when fishing through pipe.
Jlarson
I use a regular steel tape for most stuff, stainless if I'm pulling through old underground that most likely has water in it and a fiberglass tape for aluminum rigid.
Mustang51js
Haskell nj
It depends on the situation, no insulation in walls I use a chain or metal snake,if I go up the vent pipe or more than one story I use the fiber fish. In pipe I use the metal snake
Mustang51js
Haskell nj
I like the jack chain method when I snake into a switch box from the attic,small hole in the box with a hole drilled above and usually the chain drops right into the switch box
ishiboo
Oshkosh, WI
I just bought the Klein 250', as I had about a 220' pull to do. Worked well. Wish I knew there was stainless - it's already rusty.
zmaxmotorsports
South of omaha
I use what ever is at disposal,If its a bunch of new underground work in plastic Ill usually use my shop vac to **** string through it for pulling.
For emt I normally just use my old metal fishtape,or try and blow a mouse through it with string on an empty pipe.;)
mobiledynamics
Gotham City
For those chiming in, how do those greenlee conduit pistons work if you don't have their dedicated blower....that has the inline port for a string. I'd be curious how do you guys use something similar.
Mr_fixit
Rustylvania
3/16 or 1/4" Fish sticks for fishing insulated walls, or above ceilings, or above drywall, nylon sometimes for conduits with live wires, 1/4" Fiberglass for longer conduit runs, stainless or fiberglass for anything outside that might have water in it. Shop vac with a plastic bag for new outside conduit runs, or 1/2" fiberglass for 3-4" runs of 250' or longer. Or Drop a chain down for uninsulated walls. Or a combination of the above. And sometimes magnepull with a fish for insulated walls.
Beemer533
Syracuse, NY
I've had good luck with a shop vac and a piece of 1/2 EMT taped up as a nozzle. Also use the shopping bag trick or plastic bag frequently if I don't have a conduit piston handy.
