Do rodents chew PEX pipe?
jack stand
Lakes Region Maine
How many miles of plastic Street or well connections are out there?
Scary thought.
I'm hoping that at least I'm ok with my well line 5'+ deep because of the frost depth and most of it is in the ground water table. (at least when I dug it)
cpakalolo
Water line going to a hydrant leaks. We finally dug it up. I dug a few feet with the excavator and finished with a shovel. Check out these two holes- rodent chewing?
Look closely, it's not rodent damage. Their incisors leave arched cuts with a raised strip between the teeth. And with the water on, it couldn't have chewed a second hole. Something else damaged that PEX. PEX is not for direct burial by the way.
manwithtools
Lebanon, TN
Look again, seems the bite marks are just as you describe. Don't know why it couldn't chew a second hole after the first one, water on or not
BTW, most PEX is rated for direct burial.
Firebrick43
West central Indiana
The one on the left is at an angle and hard to tell but the one on the right side hole sure does.
The damn squirrels like to chew on my tank monitor antenna housings if they are close to the woods and looks exactly like that. If I wasnt in Wisconsin right now I would post a pic. It seems to be just certain animals for some reason. Some places will not have an issue but another place they will destroy a monitor in a few months and then start on the next one. We started using a pepper based bitter spray with mixed results on problem tanks.
I imagine its just like people that have mental issues with eating in editable things like hair or finger nails.
Shiftless
East Bay SFO
We have lots of gophers in our neighborhood. A few years ago one of my landscape lights went out. I tested for voltage at the socket and got zero. I dug up the direct burial wire and found those teeth marks through the heavy insulation and even through the stranded copper wire! I reinstalled fresh cable and for protection put it through PVC conduit. No problems since. 😎
matt_i
I think it's the rabbits because that's the only animal I see, but they chewed the plastic grating end off my PVC sump pump discharge pipe. Just the outlet end. It got frozen in winter and I think they wanted the water...
signcrafter
I would guess rodent also, not sure what piece of equipment(hand or powered) would cause marks that look like that. But there are a lot of other marks on that pipe also, maybe rodents scratching or from your shovel digging it up? I would think that you could dig a little ways out with shovel and find some sort of tunnel if it was a rodent.
MOwens
Pack rats will chew through anything. You should have seen the concrete floor we tore out of my uncles barn. It was only an inch or two thick and there were holes all over it from pack rats.
Hank11
Tennessee
Squirrels here have chewed the fuel line fittings on top of the fuel tank of my truck twice and my wife’s car once and they’ve even chewed some of the PVC trim on my shop. I’ve been getting even but I don’t seem to be able to get ahead. I don’t think it’s possible to eliminate all the squirrels because more just move in to replace them.
tool_scrounge
Southern California
Rodent’s front teeth grown continuously their whole lives. They need to gnaw on stuff to wear them down. Though oddly enough I do not remember our free range house trained pet rats ever gnawing on the furniture.
manwithtools
Lebanon, TN
Was there any evidence like a tunnel etc that something had dug down that far ? Just doesnt sound likely to me ???
According to a web search, pocket gophers feeding burrows are usually 6 to 12 inches below ground, and the nest and food storage chamber can be as deep as 6 feet, depending on soil type. Seems like 3' would be well within their range of operations. They are found in Texas in many locations.
Sturgeon
W. Mt.
Oh yeah, from one corner of crawl space to the other, usually had farm animals and not good feeding practices. Even the flipping neighbors feeding there there own. Rats are bad news.
Codyboy
S.E. TEXAS
moles or gophers?
At work (POCO) weve had marks like that from squirrels on H taps, sidegrooves, wire .....
Almost looked like someone was trimming limbs and the chainsaw cut into it or like a roughcut grinder attacked it.
HoosierBuddy
Southern Indiana
Years ago I had to fix a 3" Polyethylene gas main that was installed parallel to a creek, then the creek moved over several feet and the main was left exposed in the creek bank. We installed a new main 40 or 50 feet from new creekbank, cut the old line loose, purged it with air, abandoned it in place.
About a year later I got some pictures sent to me about the weird yellow trees trunks the local beavers had used to build a dam.
Yup...it was our abandoned PE gas pipe. Suckers dug it out of the creek bank, chewed it into usable lengths and used it for construction. SDR11 pipe so almost 3/8" wall thickness.
