Replacing a water pump and the old paper gasket is pretty much baked on the iron block after 25 years. Got about half of it off with a razor blade but the rest isn't very accessible. Do any of the sprays do a good job?
I've had good luck with Permatex (blue can). Spray, let it soak 5-10 minutes, softens gaskets up, and prevents damaging aluminum to a degree.
You still have to removed the softened old gasket, the spray remover just makes it easier without damaging the mating surfaces.
Spray gasket removers do help, in my experience. But, what I usually do to those paper gaskets that are stuck on is lightly tap them with a very small hammer, and they will flake off fairly cleanly.
Practice your taps on scrap metal to get the hang of not hitting aluminum to hard. Hope this helps.
