Doerr 2hp 3ph electric motor
Nuthin Fancy
Hello all, I have a Wells Index 860 milling machine, the vertical motor has a bearing that is going out. I cannot find any info on this particular motor as far as a schematic, or parts diagram. I would like to find the bearings I need to repair it, does anyone have any knowledge on these? Thanks in advance.
nadogail
Coronado, CA
Welcome to the Forum.
KenC
oklahoma
As you disassemble the Doerr motor you should see numbers on the bearings, any bearing supply house should be able to fix you up with replacements.
I've never seen an electric motor with a non-standard bearing. Should have number(s), usually found on the edge of the outer race.
Of course, I've not seen every motor either.
