dwall174
Not really a garage related issue!
But I have a small work area in my basement that's close to my furnace. Being fairly close to the furnace, I'm more aware of any noises coming from the furnace.
I have a Carrier 58HDX060 furnace that's about 12 years old, I replaced the draft-inducer motor assembly about two-years ago & it's starting to make a grinding/winning noise like it did just before it seized-up last time.
I'm wondering if there's a way to lubricate the sleeve bushings in a draft-inducer motor assembly.
The replacement blower unit came as a assembly and there's no visible oil caps or ports.
It appears as though I may be able to remove the outer plastic motor cover/housing without disassembling the complete draft-inducer assembly, but I'm not really sure if there's any oil ports or a way to lubricate anything?
Doug
Doug
