notenuftoys
I'm working on a design that requires 30 holes drilled through 1/8" angle. I'm halfway through the first build, or prototype, and have decided that using a M18 drill just doesn't cut it. Or rather, my arms don't cut it. The drill does fine.
So, with limited cash in hand I've been scouring the used sites and I'm currently going between a few different drill presses.
Option 1: Sprunger 14" that runs. I'll need to look at it in person to know if bearings are needed, but some restoration work doesn't phase me.
Option 2: Old-ish Craftsman 10". I may or may not be getting sucked in by the 1/2hp motor.
Option 3: Old-ish China-made Delta 12", model 11-990
Option 4 was a floor model Delta that got away because it was priced cheap. Kicking myself on that one.
Option 5 is a just another generic Chinese made Skil/Wen/HF to burn through until I get some real money to spend.
I'm very intrigued by the Sprunger. It appears to be clean, little rust. I do think I'm going to go take a look at it because I might regret not doing so.
Any other thoughts, opinions? All these options are basically in the same price range, plus/minus $30.
