Bradleycole
Ok at my work we have a duralast brand drill press with a ge 5kc37ln411x ac motor and this relay? RR 43-ul . It was working fine till vibrations loosened the screw on the wall side of the power switch it sparked and we shut it down I reconnected the wire and now it runs backwards it has a revers switch that always used to just blow the breaker but now I hear the motor making noise but not moving in The correct direction. It dose run good backwards soo I don't know what to do the wire diagram is damaged on the motor and I don't know if I cold just rewire to only run forward without the relay thing. Any help would be greatly appreciated
