Dry Nitrogen setup?
ps2cho
I have always thought about owning a nitrogen tank for pressure testing, but I have no idea where to even start.
Where’s the best place to buy a nitrogen tank and regulator? Where do I fill it up at?
Anybody have experience that could give me a direction?
Something small for basic mini split and automotive use to make sure fittings are leak free before charging.
cvairwerks
Within hearing distance of Texas Motor Speedway
Local welding supply for the bottle and regulator. Online for the hoses and fitting adapters. All nitrogen you can get these days is already pretty dry...as in better than 99%. Near 100% is lab grade testing gas and it's not needed, nor do you want to pay the cost to get it.
danski0224
Near Naperville, IL
HVAC supply house will have bottle and refill. You will have to pay for the bottle and then just pay for refills. Refill is typically an exchange.
You will need a set of gauges to read pressure.
Western makes a regulator with dedicated purge, braze and a fixed test pressure settings. This is the ideal setup. I know they offer at least 250 and 500 psi test regulators.
bonneyman
Desert SW
I used dry N2 for awhile then converted over to CO2 and was much happier. You get alot more gas out of a CO2 cylinder compared to N2 (22 cubic feet vs. 9 cubic feet), so I could use CO2 for alot more tasks (blowing out condensate drains and coils, chilling my cans of soda, etc) and it was inexpensive. I called a helpline for HVAC and asked about using CO2 before buying it, and the guy told me what I was intending was fine just don't leave the gas in a system overnight for leak checking
I also bought a small 2.5 pound aluminum cylinder that I filled from my big tank for carrying on the roof more easily. The REVAC system was great!
Firebrick43
West central Indiana
Going to have to have a license however to have access to the HVAC supply house.
danski0224
Near Naperville, IL
Depends on location. Some States do not have HVAC contractor licensing requirements (I am in one of those).
If the person isn't buying refrigerant or equipment containing refrigerant, that's no problem either.
COD account wouldn't be an issue otherwise.
Firebrick43
Our state doesn't have licensing requirements either (except EPA for refrigerant obviously) but no HVAC supply house I know will sell to the general public. They normally want to see an EPA license to "See" that you are in the trade.
karoc
Hemphill Tx
If it was me, I would buy from welding supply house for all your components. Knowledgeable person will sale you proper sized regulator and hoses that is rated properly. Keep in mind that just because it go up to say 500psi doesn’t mean you need to test at 500psi. I had small tank that I carry up on roofs to repair package units then test make sure my welds were good. It really doesn’t take that much psi to test
dcg9381
Austin, TX
Can't you get nitrogen at the welding supply house? I know you can get mixes.
I see guys in the 4x4 world carrying nitrogen tanks for tires sometimes.
I've seen quite a few setups for sale on FB - I've got a C02 setup, but use nitrogen so infrequently that I've never bought one.
Firebrick43
Yes, most welding shops have nitrogen. We had bottles of high purity delivered for a laser welder last place I worked.
When I was a teenager my father repaired aluminum gasoline tankers. I helped sometimes to ventilate them, we got the large dewar of liquid nitrogen to purge them as we made the cuts to prevent explosions
