Duohex Boxocket pat #1424069
leg17
Kentucky
I believe I have seen offset 12pt DBE wrenches both by Williams--Duohex and BluePoint/SnapOn--Boxocket marked with the same patent number, 1424069.
Anyone know the story behind this?
Posting on the other side of the tracks as well.
L
leg17
Kentucky
Patent summary didn't list an eventual assignee.
Did he license both of them?
woody 73
The Great State Up North
Honey child you want answers then tell us that you are posting on the other side of the tracks...Well I guess the grass must be greener over there.
L
leg17
Kentucky
Alloy Artifacts
Williams
Round-Shank Box-End Wrenches
Williams introduced 12-point box-end wrenches some years after the first "Superrench" wrenches were offered. Although the exact date is not known, box-end wrenches were definitely available by 1931, based on an A-373 catalog update from that time. These first generation box wrenches featured round shanks and were marked "Duohex-Box", with "Duohex" signifying the double-hex (12-point) broaching.
The early 12-point wrenches were also marked with a notation for patent #1,424,069, issued in 1922 to F. Blackmar. This patent describes the design of a 12-point box wrench with an offset handle, and appears to have a bit of a curious history. There's no patent assignment listed with the initial patent document, but Snap-On seems to have acquired it at a later date, possibly around 1930. In the early 1930s Snap-On marked some 12-point wrenches with the patent number, and a few other companies did so as well. (Snap-On also marked some 12-point sockets with the patent.)
The Williams catalogs for 1931 and 1933 acknowledge licensing the Blackmar patent, but by 1937 were no longer mentioning it in the catalogs. Thus the presence of the patent marking on a wrench indicates a likely production date in the early 1930s.
RedVise
Gulf Coast, Fl
Dredging this up from the past.
I came across a double box end wrech with a single offset, a favorite of mine. It has the patent number 1424069 and is marked S-9053 and 5/8. No makers name.
/alloy-artifacts.org/snapon-bluepoint-tools notes this:
Offset 12-Point Wrench
Originally used by APCO
Patent acquired by Snap-on ca. 1930
Interesting that it has no makers mark. Did i mention someone used a torch on it.... !!
L
leg17
Kentucky
Doesn't sound like a normal part number.
"S" sometimes indicates SPECIAL.
I need to do some detective work on this one.
