CaptinCrash
what duzs tools are u guys using
Dzus fasteners are a type of quarter turn fastener that uses a mounted spring wire and a screw type stud with a slot and cam in it to engage on the wire. They were developed before WWII to retain cowlings and panels on aircraft. Not used on aircraft any more, replaced by several varieties of cam-loc fasteners now. DFCIS is the successor owners to the DZUS company.
http://www.dfcis.com/
http://www.dfcis.com/history.html
Look here for visual ID of quarter turn DZUS fasteners....
http://www.dfcis.com/dzqthome.html
Charles
WOW - that's quite an elaborate presentation you have there Charles.![]()
The only tool you need for a Dzus fastener is a screw driver (slotted)
Willy
Willy
Bottle opener end of a church key.
jerry
A quarter. Even a nickle will do.
For items that go off and back on regularly you want proper fitting tools. Screw drivers have tapered sides that will engage at the top edge. A lot of these fasteners are aluminium so having a properly sized tool that fits is desirable. The small socket here is #3 - 1/4 dr and the larger ones are #5 and two #6 in 3/8 dr. The #6 is about 5/8" across.
