Electric downdraft cooktop installation
scotw
NC, near Raleigh
I need to finish this project so I can get back to work on the garage!
I currently have a 18 year old JennAir electric downdraft cooktop which no longer works.
I intend to replace it with a Gas unit next year, but purchased a used GE electric downdraft cooktop (Model P389BJ1BB) to use until then. This weeks project is to install it before the holidays.
The current service is a 50 amp 2 conductor + ground 6 gauge aluminum wired directly into the cooktop (no junction box).
The new GE cooktop is 8KW.
The installation instructions are pretty vague (page 34).
http://products.geappliances.com/Ma.../Dispatcher?RequestType=PDF&Name=49-80387.pdf
Here are my questions:
1) What size junction box should I use?
2) What size wire should be used between junction box and cooktop? Is 10 ok or should I use 8?
3) I don't see any wire nuts at local stores that will work with 6 AL and 8 cu. How these connections usually made (polaris connectors?).
4) Does the grounds have to be connected to the junction box? In JennAir's instruction, they are not (page 11)
http://www.jennair.com/assets/product/JED4536WS_Installation Instruction_EN.pdf
5) I do I mechanically connect the grounds and neutrals together? Neutral + ground from the cooktop to ground from service and possibly ground from junction box.
Thanks,
Scott
Stuart in MN
Minneapolis
The picture in step 7 of the instruction manual on page 33 indicates you can make electrical connections directly to the new cooktop. Is the existing wire long enough to reach?
Since your existing circuit is 3 wire, use step 10 of the instruction manual on page 34 for making electrical connections.
scotw
NC, near Raleigh
Step 3 of the instructions say to install a junction box, so I don't believe I can direct wire into the cooktop. I thought a junction box was also a code requirement. Thats what I mean about the vague instructions! I still need a safe way of attaching copper and aluminium wire together and how to handle the grounding of three large wires in the junction box.
