Motofixxer
- Joined
- Oct 10, 2009
- Messages
- 695
For years I have been bleeding brakes with my little Hand vacuum pump, or the help of another foot to pump. Well I decided to change that. So after a little research and a little fabrication this is my result. I didn't want to put a lot of $ into it. But I did want it to be very functional. So for a basic description it's using a plain old $20 tire inflator which was modified with some epoxy and a 1\4" hose barb to cover the intake of the inflator pump. Then some plain old 1\4" ID rubber hose, a couple of hose barb fittings. Then finally a "watertight" container I found at my local wally world in the camping accessories. The inflator is not permanently modified and still works perfectly. I did put one of the included straight through nozzles in the inflator tire valve end to permit the air exhausting from the inflator outlet hose. Another idea is to cut the whole valve off and leave the hose bare. But that would permanently modify the inflator. My hand vacuum is connected by hose and Tee to view vacuum, also not permanently modified. And finally the container which may need modification, but esentially works. One barb epoxied into the top cover, which actually needs to get swapped for a screw in type fitting or tire valve drilled out to 1\4". The other line is simply 1\4" brake line with an angle cut on the bottom to permit flow while sitting on bottom of container. Then epoxied through container cover with hose attached with a clamp to tighten the fit. The brake line needs to be changed to run through the center of a drilled out screw in tire valve etc, because of vacuum leaks after a while through the epoxy in the lid. The container might need to be switched at some point to a stronger one because the top actually flexes in a fair amount at full vacuum which appears to be about 23". The setup actually works faster than I thought it would due to the larger container. And it has a fairly large capacity with the container. But its pulling vacuum almost immediately and can easily maintain a strong vacuum while bleeding lines etc. I have started thinking of all kinds of uses for this now such as evacuating floor jack oil, differential fluid changes, brake \clutch bleeding, P\S fluid changes. I think I will be using it much more now and maybe you can think of more ideas or improvements for the idea.
