lbgradwell
Hoping someone can help me here...
I installed a low-voltage light fixture (6 @ 12V lights) in the front hallway of a friend's house that is controlled by a standard switch. If left on for more than - say - 30 minutes, it would work fine until turned off. If it is turned back on again within a minute or so, there's no problem & it continues to work fine. But if it's turned off for ~ 3 minutes, it won't turn back on and I need to wait for 10-15 minutes before it will work again!
I am aware that a LV fixture requires a special LV electronic dimmer, but this is just a normal switch...
I have a theory, but want an electrician to confirm it for me...
I tested the supply at the ceiling box and discovered the voltage there is 126.4VAC. As that is higher than I had ever seen before, at first I thought the breaker was perhaps faulty in some way, but I tested other outlets on other circuits throughout the house and found some as high as 127.3V.
I also put the meter on the 12V sockets on the fixture and they seemed to be 8.5V or so which makes me think the transformer in the light is working OK.
QUESTIONS:
Firstly, why is the voltage so high in the house?
Secondly, is there any way that the 126.4 volts might be a touch too high for the transformer in a 12V LV fixture. Is it possible that the fixture overheats due to this slightly higher-than-normal supply and needs to let the heat dissipate before it will work again?
Thirdly, if so, is there some type of voltage regulator or something else that will solve the issue?
All help is appreciated!
QUESTIONS:
