Electrical Load Sizing Calculations
apeters62
North Carolina
So, bear with me here, I'm just trying to learn. I'll consult with an electrician as soon as I can find one to actually do the work.
I'm having new service ran to a new shop on my property. Duke Energy's electrical engineer came out and gave me a Load Sizing sheet I need to figure out to determine total kW. I understand how to get kW but I don't understand his graph.
I would think that kW would be determined off of actual amperage pull from a device/appliance but because the sheet lists receptacles I'm thinking it's based on individual receptacle size. In other words, if I had (10) 15-amp receptacles would I be looking at 150A or only 15A if they were all on a single breaker?
For hardwired items like an Air Compressor, again I would think I would need to know actual amperage but the only published information I can find on any device/appliance is the recommended breaker size. In this case 30A at 240V. So I would use those numbers to come up with 7.2kW?
Really, the receptacles thing is the most confusing since it's such an undetermined20221027_082120.jpg thing. But I'm sure this is a common thing for an electrician.
u2slow
BC
A load calc is a very specific recipe that factors in the large loads of a home, plus allowances for square footage. It is not a sum of receptacles or lights.
Code has a large section dedicated to load calculations. You need to know it to do one properly. Or find a website that attempts to simplify the process.
A
apeters62
North Carolina
Thank you, I thought it might be more in depth than face value but the engineer didn't seem to think it should be overly complicated.
you dont just add up nameplate amps or receptacle amp ratings. its more complicated than that...
mike holt has a simplified load calc spreadsheet but its for residence only. you may be able to find one for a "commercial" building
