Electrical loads
99SVT
I'm adding a bathroom in my shop. In doing so, I'm going to have an exhaust fan/light in it.
I have 9 110v outlets at numerous spots inside the shop (3 to a circuit)... each circuit on a 20 amp breaker.
My thought was to just tap into one of these for the supply to the exhaust fan/light in the bathroom. Well, it seems that the fan pulls 24 amps.
Keep in mind, I have never done anything like this before (framing, elec., etc.), but am fulling capable of doing the work, if shown, read, or explained what to do.
I thought about just replacing the breaker with a bigger breaker (30 or 40), but I don't think the 12ga wire that is run will support this.
Is my only option running a new line, with heavier gauge wire, from the breaker box to the bathroom?
oleguy
exh fan won't be 24 amps.think you mean 2.4 amps.light and fan 3- 4 amps.20 amp ckt will be fine.
99SVT
Thanks for making me go back and look... it was 24.5 Watts. :lol_hitti
Ok, lets say it was 24.5 amps... would the rest of what I posted be correct, in that I would need to run a new line for it. A person can just swap out the circuit breaker... unless the wire is capable of handling that new amp rating.
larry_g
oregon
Ok, lets say it was 24.5 amps... would the rest of what I posted be correct, in that I would need to run a new line for it. A person CANNOT just swap out the circuit breaker... unless the wire is capable of handling that new amp rating.
You are correct. The circuit breaker is there to protect the WIRE nothing else. There are all sorts of wires, routings, heat, and other factors that determine what rating a given size wire is to be fused at.
lg
no neat sig line
tfi racing
Cedar,BC
If that bath fan was 24.5 amps,I would have to ask what the hell are you eating that stinks that bad!:lol_hitti
On this side of the border,tapping into one of those general circuits for a small bathroom would not be an issue,however,your local rules may vary...
99SVT
got it all wired up today... everything works like a champ.
Thank ya'll for the info & help.
imavanner2
Jackson NJ U.S.A
If you were doing this with a permit Nec states that a seprate 20 amp breaker be dedacated to the batroom only. If i am not mistaken.
sberry
Brethren, Michigan
There are several rules specifically pertaining to bathrooms. But, as for running the fans and lights this is not an issue to be running them from another circuit.
