Enclosures for electric or electronic projects
pcmeiners
The last few times I have searched for metal enclosures they are either uselessly thin or very expensive even on Ebay, new or used. Rather painful when the guts cost less than the box. Searched Ebay the other day, anything of quality was $100 or more.
Anyone have a decent supply source ?
tonyciambrone
Northern Illinois
TuxThePenguin
Only nice-looking ones I know of are the expensive aluminum ones
All the cheap stuff I know of are those project/hobby boxes like the ones at Digikey as linked previously (and other suppliers similarly like Mouser, Parts Express, etc.)... very, very, very, very ugly. But functional
slow
near Orlando
I like to use Hammond Extruded Aluminum enclosures, they are somewhere between thin **** and $100, some have metal end caps others plastic. All depends on what size you need.
nadogail
Coronado, CA
Have you tried an amateur radio supply house, they used to be located on Cortland Street in Lower Manhattan.
P
pcmeiners
Brings back memories, I use to go there and Canal street every couple weeks. Good used large boxes went for a couple dollars in the 70-80s. It has all disappeared, the rents are now astronomical. In the early 70s you could buy new surplus rocket engines or an Ethelene oxide generator ( used in Vietnam tunnels) on Canal.
Need to save the links you guys provided for the next project, thanks. Some of the Bud cast aluminum boxes are real nice
930dreamer
Amarillo,TX and Stinnett,TX
I bought (5) of these for $100, not sure what size your looking for, surplus stores would be a good source. I bought off lots from Habitat for Humanity also.
pwhittle
Woodstock, GA
I built a replacement controller for my RV and ended up 3D printing the enclosure.
I have about $400 in my printer setup but each 3x4x1.5 box costs $2 in filament. I have built 30 so far and have plans to build another 30.
I also have produced an ABS replacement for something I turned up on my mini lathe. I am not very good/fast on the lathe. Once I got the design right, I can print multiple copies while I do something else.
Paul
Sent from my iPad using The Garage Journal mobile app
CoogarXR
Call me a hillbilly, but for small projects, I have been using old data cassette cases. I was in IT for a lot of years, so I had all kinds of tape cases in all different sizes. They are a nice soft plastic, easy to drill without cracking. Default is clear or frosted, but you can paint them easy too.
Last one I used was a small DDS cassette box to make a manual lockup torque converter controller for my old turbo van. Just two buttons and a pilot light on the short edge. It was the perfect size.
Colorado
I don't know if it is in your budget, but Hoffman boxes are about the best and are used extensively in the Electrical world. They make so many different combinations.
https://hoffman.nvent.com/
Give it a look and then search for a vendor that has what you may need.
I hope this helps
Landon
