Innovate1
Read a little about epoxy needing 55F or above to cure. They got one coat down but the weather turned cold and wet so it has been a couple days. Temp inside is heated and 65. I will check again but after about 36 hours it was still fairly "plastic" - it wasn't tacky on the surface but was soft. What's going on? I also saw something about recoat time. So apparently the surface needs some sort of prep before another coat. What prep is needed?
