Epoxy problems
jvelcro
Pittsburgh, PA
Hi,
I painted my garage floor a few years ago with the rustoleom 2 part epoxy garage system. Prior to doing that, my expansion joints were a bit messy because they cut them with a bad blade. So i decided to fill them in with some sort of home depot concrete patch stuff (not sure what it was now). Well, the epoxy is doing well, except where i patched the expansion joints, i obviously doesn't stick to that product at all, so now it's chipping up on those lines. I assume all i can do is try to scrape up all of that epoxy. Then, will i need to try to scrape or grind up the patch compound? Then what should i fill it with so the epoxy sticks?
All of that then aside, can i put another coat of epoxy on top of the 2 year old epoxy? I can't find any information on prep for that.
Thanks,
-jim
