Evaporative cooler wall switch wiring
930dreamer
Amarillo,TX and Stinnett,TX
Good evening,
I need to wire up the switch and stuff it all in a gang box. I'll use all four of the lugs on the back of the switch. What's the correct way to attach wire to these lugs- use terminals? The ring terminals I have don't fit flush(heads to big) what about a spade ? I'll have eight wires in the gang box.
  • 83073b2a-2736-4a66-a167-a469ab8b82e9_1.2d85701a309e9bfdd964c9436c8771cb.jpeg
Jim greengo
Behind my house
Do those nuts come off on the back?
Hard to tell from picture.
If they do yes I'd use some stak on connectors on them.
What kind of a cooler is is going on,inside or outside of cooler?
Norcal
I use a ring terminal, you need 1-line conductor, & 3-conductors out, 1) high speed, 1) low speed, 1) pump. It makes things easier/simpler if a conduit is used between the switch & cooler rather then using NM cable.
930dreamer
All done and it works. And you know it was windy as hell when you see this in the swamp cooler.
