Exhaust Fan 220 vs 110
jdub63
Azle, Texas
Yesterday I received my new 24" exhaust fan. The motor can be wired with either 220 or 110.
Can someone explain the advantages/disadvantages of each?
Additionally, how is the 220 switched? Is there a unique switch for 220 that will kill both leads?
I would appreciate any constructive comments.
MoonRise
Advantage to 120V (aka 110V aka 115V) usage: More 'common' in residential wiring.
Advantage to 240V (aka 220V aka 230V but usually NOT 208V, although some devices are 'compatible' with 200-240V) usage: Half the amperage draw compared to 120V operation. That means for 'high' amperage-draw devices that there is less voltage drop in the wiring and the wiring -may- be able to be done with slightly lighter gauge wire and a smaller circuit breaker.
Switch would be a 2-pole switch, like this:
http://www.hubbellcatalog.com/wiring/section-c-datasheet.asp?FAM=Switches&PN=HBL3032
Available here (and probably lots of other places as well):
http://www.grainger.com/Grainger/HUBBELL-WIRING-DEVICEKELLEMS-Industrial-Grade-5Z807?Pid=search
Stuart in MN
Minneapolis
What size is the fan motor? For anything under 1/2hp or so, there's really no advantage in wiring it as 240vac. Above that, depending on the size, it will save you a little on wire gauge and circuit breaker capacity.
