Exposed Roof Insulation Question
kngelv
Detroit, MI
I recently had a 22' x 24' garage built. It is a typical garage with 8' walls and a center peak around 12'. It has continuous soffit vents and a ridge vent. The walls are insulated and covered. I want the ceiling insulated but want the attic area open for storage, so any insulation must be attached to the underside of the roof. Based on that I have – I believe – two options. I can have spray foam installed making the roof completely sealed or I can run baffles from vent to vent and install kraft faced batts. I am wondering if there are any issues with the kraft faced batts being uncovered? Thanks.
James
