Fast-Flor
Burner
Canada
Do not use this in your garage it will not last! It may be cheaper than some of the other brands but you are just as well burning your hard earned cash than using this stuff. It is just too soft a material for vehicles unless of course you only own a Smart car, then it might be okay...
Fast Toys
Winnipeg
I think you are referring to the original Fast Flor tiles which had the pattern that was open through the whole tile and allowed rocks and such to get stuck. This has been changed and the new style is completely different. The specs are equal to or superior to other tiles on the market. I believe they are rated at 14-16000 lbs per tile.
The only openings in the tile now are in the expansion joints and far too small for rocks to get stuck in there. Those areas are also recessed.
