Female torx plus
Have you ever needed a female torx plus socket?
  • Have needed this type of socket?
    Votes: 13 31.0%
  • have never needed this type of socket
    Votes: 29 69.0%
  • Total voters
    42
  • Poll closed .
Gtamazing
Fort Erie On.
I didn't even know they existed. I use torx plus screwdrivers on occasion in certain European cutting tools. I think if you buy 10 sets you might have then for a while. but thats just my .02
R
rhandwor
Get a quote from [email protected]
I'm not sure and if you need them Frank will get them for you quickly.
Nissan uses a few for transmission and head bolts.
GeorgiaHybrid
Extreme NW Georgia
Try pulling the carb on a late model B&S engine without one.....
Not to mention some GM air bags and ignition swithes, bell housing bolts on some Jeeps and several more that escape me at the moment....
R
rhandwor
These are not bit sockets but Etorx sockets like a E16 female torx. As far as I'm aware Snap On makes a 3/8 drive 10EPL a EP18 GM seat socket and a 20EPL for Nissan flywhell bolts. The 10EPL fits a Nissan transmission bolt.
JTC makes Ribe sockets for Nissan which I think fits Female torx plus bolt heads. For Nissan head bolts, clutches and other uses.
I've never seen any made by Gear Wrench please post a link.
J Kent Moore also makes some including an EP8 for hybrids listed on Ebay.
billybudge
UNITED KINGDOM
I have found that I have needed to use female torx a lot more these days, to an extent that I had to buy a complete set of 1/2 and 1/4 sockets plus others,
a lot of european made machinery seem to use these fittings as well as more cars, I have found Fiat seatbelt bolts now use this cap,( on some models)
and they are more populer in europe than whitworth, sorry to say,
84TurboBuick
Illinois
I have a Craftsman set that I got a while back.... I had to use them, and my two neighbors both borrowed them in the same weekend.
rua1972
I had to replace a flywheel on a Saab 9-3 diesel. Almost every bolt was e-torx. I had a set of sockets already i now have a set of e torx wrenches as well. Opel/Vauxhall uses this type of bolts a lot also.
R
rhandwor
Everyone is commenting on female torx I'm asking about torx plus. Look at the picture of the bolt. The special socket Snap On makes is a 20EPL while Koken makes the same socket the special tool is made like a torx with widened ends. This is like a Kent Moore.
http://www.koken-tool.co.jp/en/imgs/panflets/KOKEN201102EN_6.pdf
Look at the bolt picture I found a GM seat nut which is an 18EP a E18 wouldn't fit but a E20 would work. I have a 18EP snap which fits a Koken 18 EPL will also fit.
My first comment has a picture of a set of EPL sockets.
MrMark
Southern Cal.
I'll be on the lookout for these, but I've never seen one, just regular ETorx all over my car. So, no, I wouldn't buy this. I would only buy them one at a time, if ever needed, and I would at least wait until needed, because they are so rare. I do have a bit set of male TorxPlus, and those seem to be a little more common, plus it is economical to have such a set "just in case."
GeorgiaHybrid
Extreme NW Georgia
Look at the bolt picture I found a GM seat nut which is an 18EP a E18 wouldn't fit but a E20 would work. I have a 18EP snap which fits a Koken 20 EPL will also fit.
Oops...
My mistake...Never used an E Torx Plus at all.
rua1972
I was to fast with posting as well, sorry bout that.
Never seen those e-torx plus type bolts.
