Fiberglass insulation help please
bchee
Texas
This is probably a long-shot but I'll ask anyway
Found some fiberglass insulation on CL, seller says they are 5 ft tall rolls.
I'm assuming they are commercial use or something like that.
Do these rolls come in a standard size? Or a standard sq ft coverage?
Seller is unsure of dimensions.
Figured I would ask here to see if anyone knew, in case there is no info label on the roll, and I can't unroll the whole thing to measure it. THANKS
jaybug56
Rockbottom, Illinois
Standard size would be 16 inches wide and 8 feet long. To fit a normal wall cavity. 24 inch wide would be for a ceiling. Kraft paper backing should be there for a vapor barrier. Some deals aren't very good after all.
bchee
Texas
I don't think this is a standard residential size. I think it's commercial use cause it's a huge 5 ft wide (tall) roll.
The picture isn't very good (CL ad) but imagine that roll being 5 ft tall.
bchee
Texas
It turned out to be R-19 for 20 cents per sq ft. Did I do ok?
just a roll, not faced or any of that comfortable to handle stuff.
NUTTSGT
Northern Central Ohio
If you already bought it, it's irrelavent if it's a good deal or not.
If you can get those rolls into your attic and you already have FG batting, I know what I'd be doing with them. I'd roll them out across the rafters and blanket the attic with a second layer. Like the picture in the link.
http://insulation.owenscorning.com/homeowners/insulation-products/rooms/attics.aspx
