Filling cracks in garage floor
GerryinBelleRiver
I have an older home and I am looking to put a coating on the garage floor which has 3 or 4 wide cracks. The cracks are about 1/4" wide and appear to have been filled with caulk of some kind that has come out in a lot of places. I would like to remove the caulking and fill with something more appropriate.
Question is what should I use to fill the cracks?
I will probably top coat with some concrete paint as the floor was previously painted and the paint is still on about 50% of the floor. The garage rarely sees a vehicle but I do have a lot of heavy woodworking equipment on mobile stands that gets moved around a lot. The other reason I will probably paint is that I can only free up 1/3 to 1/2 of the space at a time and I am not sure I could get a clean joint with epoxy.
Comments and suggestions welcomed
Thanks
carhunter
southern Ohio
Check out the 44 Frame shop thread - cracks just add character to the shop :)
I'd suggest hydraulic cement, but its likely nothing will really last all that long in a floor that's already cracked.
Garage Flooring
Grand Junction, CO
If you have some pictures it would help. There are some great products through any of the epoxy people for repairing. I would go with whatever brand of epoxy you are going to use.
pauls340
North of Motown
I was at a Detroit Tiger game last month and noticed one area inside the stadium where they crack-chased the cracks about a half inch wide, filled it with a quality joint filler (caulk) like Seal Bond and all the people traffic turned it dark gray/black and it kinda looks like tiger stripes.:rocker: Also, in my world, Mother Nature wins 100% of the time.
