Floor epoxy
daveycrocket
Portland Oregon
I'm currently remodeling my two car garage. Due to severe cracking and about a foot of earth missing under my garage floor it's been replaced with new slab.
The epoxy coating will be applied August 17th after the concrete has cured 45 days.
Beside my two of my three cars I can fit my motorcycle in a pocket area of my garage.
With epoxy flooring will my side and center stand use damage the epoxy?
Just wondering if I need to order Race Deck or Swisstrax for protection.
Shea
California
Much depends on the system being installed, however, no coating system is going to be impervious to scratching from a motorcycle stand. The bottom of the stands are like a cheese grater from being used on various surfaces.
I would recommend purchasing a kick stand puck for the side stand. You can find dozens of examples on Amazon. If you use the center stand quite a bit in the garage, you can purchase an inexpensive 2'x3' oil mat to use the center stand on.
The other option that you mentioned is to have your own parking pad. We have an article in the link below that provides quite a few options. Good luck and post pictures of your floor when you are done!
https://allgaragefloors.com/best-motorcycle-flooring-parking-mats/
