Floor Jack Lincoln ??
butchfig8
Think I have Lincoln W93642. 4 ton? Series E
red plug is Press bypass ckt maybe ??
Anybody know of parts that are supost to be in this
Press bypass ckt ??
Where to get these parts ??
Drawing of where they go ??
Hiball
Missery
If its a W93642 its a 2 ton, I'm unsure of what your asking for sure, but that plug isn't OEM.. Lol.
Here is a tutorial for a 93632 that shares components with your jacks valve system.
Exploded view diagram for 93642
Left side is overload, right valve is the working valve.
pop pop
Virginia
What I know I got from Hiball. Till he gets here..... You may be right on the model, but it's not a 4 ton, likely a 2 ton. First the two holes should be covered with Welsh plugs. The red one is the relief valve. There should be a slotted screw thread plug that holds in a stiff spring, bottom spring seat and small (bb sized) ball sitting on a seat at the bottom, as best I recall.
OK the boss is here!
EDGAR
Out of curiosity and since it is not shown in the pictures, does it says that it is actually a Series E? Up to series C, the jack used an u-cup sized 15/16" x 1-7/16" x 1/4". From series D the size of the u-cup was changed to 7/8" x 1-1/2" x 1/4". Just so you know in case you need a repair kit.
Check Blackhawkparts.com, they sell the valve parts individually. When you know the parts numbers, send them an email, so they can quote a price.
http://www.blackhawkparts.com/
Just in case you need it, check below a parts breakdown for a Lincoln Series C.
http://www.ohiohydraulic.com/lincoln_jack_jpegs/93642-C.pdf
butchfig8
Thanks for the info
this is a hand me down, guy said it just stopped working,
that was before he lost all the overload side parts.
I will price out parts before I tear down jack.
As for Series E or D or C ?? I do not know how to tell ??
-38 deg outside fishhouse in N. Minn this am :lol_hitti
pop pop
Virginia
FWIW, this jack is not a virgin. Someone has opened it up previously as the tank is rotated from where it should align. I'd suggest a complete tear down to see what is missing and needs replacement before ordering parts. You could need more.
EDGAR
If and when you tear it down, measure the u-cup, if it isn't broken in many pieces, or measure the cylinder inside diameter and compare it to the measurements given in my previous post (#5).
Hiball
Missery
Or if you don't trust your measurements, snap a picture of ram end with the white guide in place and I know how to tell by simply looking. Yeah.. I'm good like that.. Lol
In all honesty the majority 642 kits carry both cups, I know I do if so one is unsure of what they have and need the kit now..
Edit.. I shouldn't say the majority, not every reseller assembles kits to cover all series.
