Floor tire blocks
opticle
Hey all,
Thanks in advance! I'm not 100% sure if this goes in this forum area or not, but it's related to the floor.
I want to install some tire blocks in the floor (concrete w/ VCT tile over top) but have the blocks be removable. I was wondering if anyone has done this. The blocks are supposed to mount via anchors and bolts, but I'm going to need to remove them pretty often (for different vehicles and to lay on the floor where they will be located). I was thinking I could use detent pins, but curious if anyone else has done something similar and has any suggestions aside from bolts.
Thanks!
65ranchero
Danville, VT left NJ forever
I use a piece of landscape tie with a 2x4 screwed to one side which lets the tie lean away from the tire .
Used on concrete floor
mark the floor spot so chock can be put back in same spot every time.
For your case rubber chocks would be better.
