Flourescent lights in cold weather.........
jwillis
SW Ohio
I am wanting to put some flourescent lights in my outbuilding/garage. It will be cold out there in the winter, down to freezing. I won't be using them that much, but if I do need them I know that they won't be very bright. Right? I now have four- 125 watt flood lights on the ceiling that point toward different areas. So what kind of 4' bulbs should I use? Any help would be appreciated. Thanks. :headscrat
ripsnortMN
Mn
Get flourecent lights with cold start ballasts. Mine go down to zero degrees and will fire right up with no flicker.
Stuart in MN
Minneapolis
If they're T8 lamps (the newer, skinny ones) they should have electronic ballasts that are good down to 0 degrees F.
Norcal
Add tube guards to the lamps, they will keep a jacket of warm air around the lamp(s) as FL lamps need a bulb wall temp of 100 degrees F for optimum light output, plus contain the glass if they happen to be broken as a bonus.
ddawg16
S. California
I've seen them light up down to -20F. Takes a min to get to full brightness....but then again, I'm kinda liking it....at night you don't have that sudden brite light that has you blinking while your eyes adjust.
J
jwillis
SW Ohio
I was wondering........are they as bright in cold weather as they are in warm weather? That's what I was concerned about. I didn't think they got as bright in colder weather.
nate379
Palmer, AK
The T8s in my garage are noticeably dim when I first fire them up and the garage is kept at 55*.
Not sure how they are going to work out at -20* but we will find out soon cause that's what is going in my shed.
bill9860
Northern VA
Agree - T8s fire right up but are dim for the first minute or so at 50 degrees but quickly get to fu;; brightness.
