FS: High quality RED extension cords
mrb
I still have a bunch of my Red cable, so im starting another thread since the old one got quite long and a little off topic. The cable is SJTW type, and is a special formulation that stays flexible in colder temps. These are very nice and flexible. The cable is imported but is very high quality. The connectors are Leviton industrial grade and made in USA, and of course the cables are assembled in the USA.
Prices as follows:
14/3
25' - $20
50' - $32
100' - $48
12/3
25' - $25
50' - $38
100' - $60
I can fit between 100 and 150' of cable in a large flat rate priority box for $16 including insurance.
I can also do other lengths, and other configurations such as twist lock connectors, 'quad box' with two duplex receptacles (junction box with 2 duplex outlets and stainless cover -NOT OSHA compliant, use these at home only), adaptors from twist lock to straight blade, etc.
The cables are hand assembled, power tool only used to tighten the strain relief. This is important as the wire clamping screws and clamps are damaged by use of a screwgun to tighten them.
Please note I am not a reseller of these coming on here to spam the board with products. For now I have only listed these here as I know a bunch of people on this board appreciate a good extension cord. I have a little less than 700' of each size of cable and when its gone, its gone (I can get more but it takes forever).
Payment via paypal (im a verified business member), and shipping is extra. Shipping will be calculated at cost using fedex ground. PM me your zip code for shipping quote, the cables ship from Southern California. Figure it will take me 3-4 days to get them out as I am pretty busy these next couple weeks.
I am out of the black/white connectors and will be using all black ones. These are the exact same connector -leviton 5266 and 5269 only difference is theyre all black instead of black/white. Here is a picture of the black connectors below.
Vinko
Los Angeles
If I remember correctly, you can make up an OSHA compliant version, right? Using those yellow composite duplex outlets? If so, I need two of those. I can PM you details. Thanks.
