Future proofing...
gsea
Do you fellas overwire for future proofing? Right now, I'm adding an outlet for 30A/240V equipment, so it requires just 10-2 to a 6-30 outlet.
In the future, who knows what I may want to use the outlet for? Worth it to put in 10-3 and a more common plug or even 6-3 to accommodate any future possibilities requiring a 120/240 outlet or higher amperage?
hh76
NE Wisconsin
Not sure how long the distance is, but may not cost all that much more to go with #8, or even #6.
sberry
Brethren, Michigan
There is not really much use in preparing for every contingency,. make it so you can but so far nothing takes 3 conductor and if you need a bigger wire its likely for another piece that needs its own anyway.
the gypsy
Montreal, Quebec, Canada
No matter how much you future proof or over think it, chances are it (the wire or Plug) will not be at the right place. I know I have tried it and cannot say that I was right all the time.
unsinkable
New England
Given the chance, I always run a 3 wire even for 240 volt applications.
This way I always have a neutral there if I need it. Sometimes you want to change to a multiwire 120 volt ckt, or maybe a 120 volt tap, ya never know.
imjustdave
Sumner WA
In a garage? Maybe a electric car charging station. If so 30 is to small. If your doing it because your sheet rocking it I would run big conduit and leave it empty
G
gsea
I think those require 40A and a 8 ga wire. But then I might as well go to 6 and have the ability for 50A... its an endless spiral, haha.
jeepinerdeep
South Central PA
Oversize conduit, deep boxes and pull what you need later.
I'm not an electrician by trade, so I don't know if it's legal, but I would leave a few pull strings in there also.
imjustdave
Sumner WA
As new cars come the chargers are getting bigger. . I think tesla can do 80+ amps right now.....
Syberia
Perris, CA
#8, if using individual conductors in conduit, is actually good for 50 amps.
