REFLEXX
Gents,
Just thinking here. What about using thin galvanized sheets for shop flooring or at least in sections where there would be lots of abuse?
Install would be easy. Just drill some holes in the concrete,and use small screws that will sit almost flush?
Under a fab area in the corner where you weld or might drop steel pieces? Welding slag will not affect it. Equipment will roll easily. very easy to clean with a mop or broom.
Down sides: shock hazard? slippery? will scratch and rust eventually?
The sheets come in 5ft x 10ft, price seems reasonable.
I'm also thinking about some for walls (4ft or 5ft up) for protecting the drywall.
What do ya'll think?
whe had tin floors in our loft in barn , kept the hay from sifting thru the floor but when it got wet it was an icerink !!!
