oldtimer50
- Joined
- Nov 5, 2007
- Messages
- 25
What is everyone using for their in garage air compressor piping systems?
I'm sorry to start off this way, but it's probably because I've been on this forum too long. If you do a search on the subject of airlines you'll find a ton of threads on what people are using. I personally use an aluminum piping system.
Here's one: http://www.garagejournal.com/forum/showthread.php?t=150794
Using a rubber hose is a very inexpensive option but it wont give you any of the benefits that a proper piping system will.
I use copper.
Steve
What exactly does a "proper piping system" offer you, other than it looks pretty, and it dents easily? The benefits to me is a hose reel on my ceiling and a couple air stations around my shop. I guess if you got guys throwing razor blades at the walls you got problems with rubber hose. I simply choose to run the hose in a place in my garage that is never disturbed. Of course I'm not running some insane compressor system for an paint booth either...
Yo Durasmack!
Hey man, not cracking on your response but Join date of 2009 and this is the first time you've posted?
You're like a walking/typing contradiction! Guess I just talk to much???
Any opinion on using a hybrid system, with a copper matrix of tube near the compressor for water cooling/collection, but with rubber going out to your drops?
Do you raise up your dial if you see water grains increase as the day progresses?
Pattenp, I've been biting my tongue on this, but what the heck, here goes....
If you don't want to answer, don't.... What's the difference if the guy used the search or not? There seems to be a lot of other guys on here who had constructive solutions to this guys question. If he would have asked " I've searched on here long and hard and know what everyone has done with their garage piping up thru yesterday, I'm am wandering if there is any new ideas out here?" would that have been acceptable to you?
As far as what I use, I use the Rapid Air flexible air line with their valves and blocks.... I've
Now hat the same setup in 3 shops and have 0 complaints! Very easy installation, easy to add to, and no leaks!
See link below.
http://www.northerntool.com/shop/to...0500&ci_sku=490500&ci_gpa=pla&ci_kw={keyword}
^^^ MORE SOUP????^^^
NO! NO SOUP FOR YOU!!!!
Bastardized half remembered line from Oliver Twist. Or maybe not, somebody call me out on this literary tragedy.
I'm not fully convinced that copper works as well in the first 25' as equivalent sized iron pipe. Copper bleeds heat well - but also picks it up quick. Iron has more mass and would - seems to me anyway - have less swings in tube temp. Copper is easier to run, for sure. Mine is going to end up as a "hybrid" of iron and hydro flex line.
