Garage floor all sealed
jpeterson1976
2 coats and shark bite. Looks like glass but nice and grippy!
Sent from my SM-G935V using Tapatalk
J
jpeterson1976
I will get a picture when I get home. I got it from my concrete guy. It's all he uses and industrial. Got it in a 5 gallon jug along with the glass that I mixed in. It applied nice and easy. Just rolled it on.
elite1
Colorado
Turned out beautiful! Thanks for sharing!
If you use this sealer, is there a concern with overcure? Will this turn yellow over time?
Gozo
Central VA
I use this exact product on the stamped concrete driveway. It does wear down with use and exposure and has to be redone every 3-4 years. I guess it would be less frequent in the garage, but you will see wear at the wheel tracks more than other areas. If its not totally worn away, running a roller with xylene solvent respreads the coating and fresh ends it up and stretches the shiny look for a bit longer. Does look nice and cleanly done in the pics. :)
J
jpeterson1976
I had the new floor put in last fall and it was sealed at that time. I will reseal every year. I detail and wash cars in the garage.
Thanks
J
jpeterson1976
I keep my garage really clean. There were no stains or anything from it being poured and sealed last year. I did a quick sweep, vacuum, then pressure washed it. Let it dry then next day applied the first coat.
Ol'WhiteCap
Henderson, CO
Your floor looks great!
Your comment with the first picture said that it is grippy. Is it shinny, AND not slippery when wet.
J
jpeterson1976
Correct. Shiny but not slippery when wet. Has a nice gloss custom look.
