In my area of CT, the propane company will no longer allow copper lines to be buried. They are now using plastic lines with some fancy (read expensive) fitting that connects to where it goes underground and where it comes out of the ground. It also requires a special tool to connect this fitting to the plastic line. It has been a few years since I last asked how much it cost per foot, but I do remember it being very expensive. I was going to install a bigger tank at my home to feed the cooking stove, clothes drier, and the 8000 watt generator. Right now, the house is served by a 100 gallon tank, and the generator has its own dedicated 100 gallon tank. The cost of plumbing the larger tank to the house was not cost effective, so it never got done. I own the large tank, and the gas company owns the 2 100 gallon tanks. There is no rent on the tanks that they own, so there is no cost savings in owning your own tank in my area, unless you are a very small user. Then they do charge you rent on the tank, and high prices on the propane when they fill it. My fill up last week for my rental property was $1.97 per gallon.
