skeletonizer
I was on my way out the door tonight and noticed that one of my GFI's had tripped. It is on a string of convenience outlets with one Liftmaster opener and it's light on the last outlet.
I reset the GFI and after about 3 seconds it tripped again. I unplugged everything on the circuit and reset the GFI again, same thing, 3 seconds and it tripped.
The breaker never tripped.
As I said I was on the way out the door so I just shut the breaker off.
I guess my plan for the morning is to change out the GFI and see if a different one will stay closed unless anyone has any other suggestions???
Can GFI's just go bad and if so is this the typical symptom?
All the outlets downstream are pigtailed with the grounds twisted and crimped.
