Goofy wright 1/2 ratchet identification
JohnDeere
NE Ohio
Does anyone know what model this wright ratchet is? Selector moves side to side. The ratchet has “41+” stamped in it as well as “N52”.E412DB72-E6B9-4D5A-8E1F-FA5E1ABDB17D.jpeg2B24BBF0-7F57-4F35-B5C8-42BE845D2F09.jpeg1DF8AD53-E373-40D8-A065-51A394CE808B.jpeg
misterbill
OTG is correct. Wright catalogs are few and far between, though. It seems like Wright was iterating quickly on ratchet designs during the early 1940s. N50, N51, N52 came along in quick succession. Not sure (yet) if there was anything between N52 and N60 (which seems to have been Wright's design during WWII). Follow along in the Vintage Wright - Share It Here thread for all the latest developments and discoveries! ;)
J
JohnDeere
NE Ohio
Figured I would post this, in case someone needs it. I found a random ball bearing inside that was preventing the ratchet from being completely put together.84193368-6764-4940-A54F-4C757885B1F8.jpeg
joel_400
Nw ohio
I'm guessing that mystery ball is part of the detent mechanism for the directional selector. Probably popped out of position when you disassembled it. Lucky it didn't dissappear! I've lost more than one from the hundreds of ratchets I've torn apart. Fortunately I've been able to talk the Snap on man into letting me clean his ratchet repair bench off a few times. Some of the small pieces/parts I've accumulated from that are life savers for old ratchets!
Joel
J
JohnDeere
NE Ohio
The ball inside was too large for the ratchet to be completely back together, no matter where I put it. So I didn’t put it back at all, and the ratchet worked fine.
Kevin J.
There is a significant difference between spare parts, extra parts, and stray parts. Nothing quite like finding a nut, spring, retaining clip, etc. to spoil your day.
