Gooseneck Light Mount Juction Box
jturpin
King NC
I am looking where to find juction boxes reasonable to mount my gooseneck lights. I want to light my driveway parking area with three goosenck canopies. I recessed the normal ocatagon junction boxes in my wall. The only thing I had left was the flange. I bought the four bolt flange thinking it would take wind and hold the light up better. http://www.electriciansupplies.com/.../P/17753/Crouse_Hinds__GRF11__-__1___Each.htm
Now when I went to install them the flange bolt holes are spaced to far apart for the normal 4x4 and octagon boxes screws. I am looking where to by the boxes to fit these type of flanges. I have found some, but they are in the $50. range a piece which seem to be high.
Thanks,
JT in NC
d.swanson
Holly Springs, NC
What are you guys using for an electrical box to support the weight of a Goose-neck light? I wouldn't expect a standard plastic box to be strong enough... Also, are you adding extra wood bracing? Metal box with screws thru the back into a 2 X 4?
CitadelBlue
Northern VA
That seems reasonable to me as well?
thdewey
Gastonia, NC
I used a metal box and re-enforced it with 2X4. I fist tried a pancake box. OOPS big mistake. It started to pull away after a few months. I cut out the siding, installed the box and braced it. Then caulked the heck out of it as well, inside and out.
