TireTracks
it was my grandpa's, used it all of his life. I was talking to my dad today and he said i could have it.
It's a craftsman 103 8" bench saw. not sure of the age, but it has the same tags on it that our 40's Lathe and my grandpa's 40-50's drill press has.
View media item 8481
View media item 8482
View media item 8483
View media item 8485
View media item 8484
The good- In almost perfect shape, only some surface rust, the arbor spins and spins and spins when you turn the blade, bearings perfect. All the controlls are free and work. It cleaned up great. For a few bucks i will have a working USA made tablesaw that should last my lifetime.
the bad- It cant tilt more than 10* or so because of this gear-
View media item 8486
you can see a missing tooth, one of many ( whole 1/4 of them are just gone). I looked it up on sears, no dice, sears parts direct has a picture of a new one, but says none are avaliable.
going to need to make a miter gauge( or find the one this came with), a stand, and once i get it working i plan to make a extention for the table to go with the one it has.
2 questions, how fast should the blade rpm be? going to need to play will pullys to get the rpms right on the motors i have to use.
Mabey the momentum of the bigger pully helps.
