FunfDreisig
- Joined
- Feb 12, 2008
- Messages
- 413
I've been reading several threads with differing advice on whether electrical service for a detached garage requires 3 or 4 wires. IOTW whether it requires a ground wire in addition to the two hots and common.
From what I've read so far, the need for a ground wire back to the meter/main panel depends on...
1 - Whether you are complying w/ 2008 NEC code vs earlier versions.
and/or
2 - Whether you are wiring it as a "sub-panel" vs "new service".
Could someone please explain what exactly a ground wire does that is not accomplished with ground rods at the detached garage?
Thanks in Advance - Funf Dreisig
and/or
, and I have a related question or two. I'm
