burleymike
Now that the price of wire has come down so much I have decided to run 100 amp service to my barn (conversion to shop in progress). Since in Idaho we have adopted the 08 NEC I understand it that I need to use UG cable that has a ground.
I know I am supposed to keep the neutral and ground seperated since this will be a subpanel.
Question 1: is since my pole barn is metal do I need to keep the panel isolated from the barn?
Question 2: I have a irrigation pump in the barn that has a ground lug. Since this pump is connected to a steel pipe that is buried will connecting this ground lug effectively bond the grounding system of the house to this pump and it's piping which would act as a ground rod?
Mike
Mike
